-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   Boost Cam (https://www.performancetrucks.net/forums/forced-induction-159/boost-cam-523664/)
Iconoclast Nov 12, 2013 12:44 AM
Boost Cam
I have a trick stage 2 kit and a low km all stock 5.3.
I would like to run a bigger cam, I was looking at the Brian Tooley stage 2 boost cam. 226/231 .605"/.598" 113+4 3 bolt.
I know a lot of people have had great result with the triple 12, but I would like something bigger.
What are the cam limits on a 5.3?
Thanks.
Noah Burns Nov 12, 2013 04:01 AM
that cam is definatly within the "limits" of a 5.3 not sure what p2v is like with that kind of lift, I don't remember what kind of clearance there is in there, I'm sure someone will chime in with that info.
03sierraslt Nov 12, 2013 04:16 AM
How much does your truck wieght and how high of a stall converter do you have or do you plan to have?
Beatdown Z Nov 12, 2013 06:01 AM
What are the rest of your truck's specs? Bigger is not always better...
roland1 Nov 12, 2013 10:01 AM
II have a stage 3 76mm and a 226/232 578/587 112+3 LSA
2800 stall.
And I think its great. I'm glad I didn't go with a smaller cam. And this cam has an amazing sounding idle to it too!
Vortec350ss Nov 12, 2013 10:05 AM
With a turbo you don't need a big cam... the small cams let the turbo spool really fast and keep it working up top.
03sierraslt Nov 12, 2013 11:15 AM
Weight is the key. You have to plan accordingly to make something heavy fast.
black00chev Nov 12, 2013 05:20 PM
My theory with cams and turbos, and I think others will approve, is that turbos don't really care what cam you use. But being in our heavy ass trucks, its best to get a cam that will help your low end torque, but will still allow the turbo to breathe once it hits full boost. Something like the triple 12 cam makes good low end torque, but allows the turbo and engine to pull all the way to 6k and a little above. A big cam will for sure let the turbo works its magic, but your gonna need a healthy converter to make it all work.
Atomic Nov 12, 2013 05:43 PM
That sounds familiar :lol:
o2camaross Nov 12, 2013 05:47 PM
I run the TU1 (225/225 .581/.581 113+2) from speed inc and I cant complain one bit. I like bigger cams with turbo
