Ammonia Instead Of Water
Cat pee is pretty much amonia.
Amonia was a good refrigerant circa 1930's, but when it leaked and people were poisoned, it tended to get frowned upon.
Stick with water. At the conditions an intercooler operates under, no liquid will be better than water at removing heat.
Ethylene glycol is a very poor heat conductor compared to water. Ammonia as a refrigerant is very prevalent in industry and freezer warehouses. It is extremely corrosive, it will eat through copper, let alone aluminum. One thing that doesn't corrode is plain steel, ammonia refrigeration systems are piped with black pipe, the condensers and evaporators tubes are steel, and the controls and fittings are all steel or stainless. I don't think you would want a steel intercooler and heat exchanger, pump, fittings, etc. on a vehicle.
How about alcohol? Methanol boils at 151 degrees F at atmospheric pressure. It would act as a refrigerant if the air entering was above 151. By boiling, it would remove extreme amounts of heat.
Ethylene glycol boils at 386 degrees, by the way. This is an indicator of its poor heat transfer abilities.
hey...don't kill the guy for thinking outside an obvious box. I mean water...come on it's so...normal.
good info mr. mikegyver!!
