Alky setting
Old Jan 3, 2007 | 06:43 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Alky setting
Where is your alky injection system set to come on?
At the advice of the Mfg. we set the controll at mid point, between #4 and #5. Now the pump comes on full green @ 3lbs boost. No more intermediate red.
I think I'll be going thru a bit of the Meth.
Old Jan 3, 2007 | 06:53 PM
nightrunner's Avatar
Mr. Obvious
did you ever get your meth problems straightened out?
Old Jan 3, 2007 | 07:03 PM
trever1t's Avatar
Yes, re-wiring it to run on an independant MAP solved the problem from what I understand.
Old Jan 3, 2007 | 07:08 PM
kbracing96's Avatar
I don't have alky control kit, but I have mine set to start to come on at 2psi and full on at 6psi. Works very smooth for me.
Old Jan 3, 2007 | 07:35 PM
Wilde Racing's Avatar
How do I change this text
Mine comes on at 2 psi and I have the ramp rate cranked, the gain is at about 95%, Mine goes solid green quick, even with the two nozzles...
Old Jan 3, 2007 | 07:37 PM
KySilverado's Avatar
On at 2psi green about 8. Control about the same as yours.
Old Jan 3, 2007 | 09:02 PM
91_bowtie's Avatar
I get into boost too easily, so I keep it at 5 for daily driving. and ramp it up to full at 9 psi.
GXPJAY
Feb 13, 2022 08:15 AM
Silveradorst07
Dec 31, 2015 12:04 AM
BigEd_72455
Aug 8, 2015 07:37 PM
Sexyrado327
Aug 2, 2015 04:08 PM
lo4x4
Jul 5, 2015 05:58 AM
