-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   Afr and timing question (https://www.performancetrucks.net/forums/forced-induction-159/afr-timing-question-518294/)
AndysC3 May 28, 2013 01:48 PM
I'm currently running a procharger d1 at about 12-12.5 psi, 20* timimg and 11.7 afr. Spraying 70% meth/water. My iat's get well below ambient temps. Would it be safe to increase the timing and lean it out more? Since my iats stay around 60-70 at wot. Just trying to squeeze alittle more power out of the current setup
franko98 May 28, 2013 01:59 PM
U on pump Gas
GMCtrk May 28, 2013 02:22 PM
Damn that's a lot of timing. Do centri blowers allow for more timing versus turbos?
tarinitup May 28, 2013 02:27 PM
Why not raise boost
AndysC3 May 28, 2013 02:35 PM
91 and 70% meth. Starts spraying at 3psi. Full at 11. And I'm looking for a smaller pulley. But my wife is pregnant and doesn't work and we have a 3 year old. So funds are somewhat limited right now
03sierraslt May 28, 2013 02:40 PM
I would not lean it out any at all, hell at that boost I would fatten it up to 11.5 esp considering the stoich of meth.
nonnieselman May 28, 2013 02:42 PM
yea me too.. i was targeting 11.2 and with 100% meth it was seeing 11.0. And 20* sounds pretty dang high for 12psi.
Jake99 May 28, 2013 03:26 PM
You got a vary hot tune there already, I would raise the boost and drop timing before I would add any timing at your current boost level. Too much timing or too lean will hurt a motor much quicker then to much boost would, let the boost make the power not timing. I run 11.2af and 15 degrees timing at 20psi with e85, 20 degrees at 12psi. Id be down at 17 or so with 91 and meth.
Area47 May 28, 2013 03:40 PM
this is the answer.
if you have the spare fund to blow it up. go for it. me personally. id back the timing down
AndysC3 May 28, 2013 03:47 PM
What I'm mainly confused about is why you have to have so much fuel and lower the timing. I understand that more air is in the cylinder. So it needs more fuel for the increase in air. But a full point? My intake temps are pretty low due to the large fmic, and the water meth. And the timing is higher than most I guess. But my logs show 0 knock. And ran the time in my sig like that
