65 f100 4.8 turbo new to the forum
so this is what i got
1965 f100 swb 04 4.8 dbw TBSS intake deka 80 on3 76 van manifolds flipped 50mm wastgate bosch044 ford 9'' going to put pac1218 springs in would like to do around 550-600 hp my questions are? 1.do i have enough fuel with just that pump? 2.i would like to do a cam maybe a ljms stage to but hope some one can chime in on drivability? 3. can this be done on just 92 pump gas? thank you guys for the responses https://cimg0.ibsrv.net/gimg/www.per...93780147e.jpeg in progress |
A mild LJMS cam should be just fine or you can go with the tried and true Isky triple 12 cam. It will make great power and be just fine to drive.
The fuel pump seems to be right on that edge for power but I feel you find out that even 500hp to the tire is more than most people will expect. In other words you are going to have your hands full and trouble even making that stick to the road with street tires. Pump fuel should be just fine for that power level with a good tune. |
ok how about the regulator? corvette will be fine?
I wouldn't use a corvette regulator, just get a normal regulator and run a return line to the tank.
ok the filter with regulator are under the bed will that be ok? also what regulator do you guys do you reccomend?
holly work great on my truck
Originally Posted by 1965f100ls
(Post 5396203)
