5# Radix, what's a good AFR for WOT?
Old Mar 8, 2008 | 05:06 PM
CashDudeHomie's Avatar
Default 5# Radix, what's a good AFR for WOT?
I finally got my wideband hooked up, and logged a WOT run and got 13.2 from 1st thru 2nd gear, on the shift to 3rd it went to 13.9. Is this too lean?
Also, it seems to always go a little leaner on the 2-3 shift. Any way to fix this?
Old Mar 8, 2008 | 05:15 PM
tarinitup's Avatar
9 Second Truck Club
I'll let the FI guys tell you their optimal AFR but 13+ is too lean. You need a good tune.
Old Mar 8, 2008 | 05:24 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
between 11.2 and 11.8 is safe. 12.1 is getting on the lean side.
Old Mar 8, 2008 | 05:31 PM
WorkTruc's Avatar
11.5 is about right.You are going to at 13.9.
If you are getting leaner as you gain RPM you better check your fuel pressure.
Old Mar 8, 2008 | 05:37 PM
03sierraslt's Avatar
Way too lean, as mentioned above 11.2-11.8. Me personally I dont like going above 11.7 I actually shoot for 11.5-11.6 I have leaned it out as far as 11.9 and got no gains so I keep it safe. IMO. Dont take it WO anymore until you get that AFR down, you are lucky it didnt blow already being that lean.
Old Mar 8, 2008 | 05:39 PM
trever1t's Avatar
Radix @ 5lbs...what kind of tune/tuner do you have?
Old Mar 8, 2008 | 05:40 PM
Thanx for the numbers, Im going to spend a few hours working on the tune tonight since the wideband is finally hooked up.
HPTuners, I'm determined to tune it myself.
And I've actually been running it like this for 6 months without the wideband, LOL. Good thing I kept the shifts below 6k or it might have blown up.
Old Mar 8, 2008 | 06:28 PM
Old Mar 8, 2008 | 06:29 PM
trever1t's Avatar
Which wideband are you using?
Old Mar 8, 2008 | 08:10 PM
brobradh77's Avatar
Honestly at WOT if your AFR gets into the 12's you need to let off.
