5.3 vs 6.2 with PD supercharger
Old 01-16-2018, 03:59 AM
LPCWS6's Avatar
Default 5.3 vs 6.2 with PD supercharger
Just wondering if you can make around the same HP with a 5.3 vs 6.2 if you're stuffing the same amount of air down both of them with a PD Blower. I would assume the 6.2 would make more power easier because of the bigger better flowing heads but how much?
Old 01-16-2018, 04:59 AM
smokinlmm's Avatar
Part for part the 6.2 should give you about 100 more hp no matter how you sclice it. I will say that a 5.3 can make good power though, mine is sporting a tvs1900 and few basic mods and it's right at 500rwhp now. Cam, springs, valves, push tubes, etc are going in next and I'm going for 600 rwhp. Stick with the 5.3 if you already have it...
Old 01-16-2018, 06:36 AM
M60gov20's Avatar
What size cam are you going to go woth?
Old 01-16-2018, 11:57 AM
LPCWS6's Avatar
I have nothing right now. I've been kicking around the idea of doing a engine swap in something and was thinking it would be cool to slap a blower on it if I did it. Obviously I could find a 5.3 a lot easier and for less money than a 6.2. On a turbo setup I wouldn't hesitate to use a 5.3 or even a 4.8, you can just turn the boost up. Was wondering if you can just pulley down a 5.3 until it would make roughly the same as a 6.2 if I had a bigger supercharger like a tvs2300 or 2.9 whipple.
Old 01-16-2018, 12:01 PM
I have a gauge for that
Atomic's Avatar
The power adder determines the final output. A PD blower has to work harder (more boost) on a smaller engine, so drive power is higher compared to a larger engine so it will make slightly less power. For instance, maxed out tvs1900 on a 5.3 will probably make 550rwhp whereas on a 6.2 it would be in the 600-625rwhp range.
Old 01-16-2018, 01:44 PM
LPCWS6's Avatar
Ok that makes sense. Two more quick questions. What's the max Hp that someone could put to a Gen4 rod and expect it to last in a motor with a PD supercharger. Also could you get to that limit in a 5.3 with a tvs2300 or 2.9 whipple.
Old 01-16-2018, 03:41 PM
Atomic's Avatar
Its more question of torque than HP. too much low rpm torque will kill any rod, but if you make your power higher then it is much easier on the engine overall. I cant answer your question of how much, but yea I would think you could do it in a 5.3 with a big enough blower.
Old 01-16-2018, 05:29 PM
LOWRIDERGMC's Avatar
I made 470rwhp with a Mp112 10-11psi and 540wrhp with a 50 shot stock 06 5.3 cam only
Old 01-16-2018, 05:50 PM
03sierraslt's Avatar
My stock Lq4 6.0 had gen4 rods and it seen 15psi and 6500 for a few years. It was still running like a champ when I pulled it.
LOWRIDERGMC (01-16-2018)
Old 01-16-2018, 06:34 PM
Vortec350ss's Avatar
I'll let Y'all know.
I have a gen 4 rod 4.8 that has a 2.9 whipple on it.
I'm planning to eventually shove 20 PSI down its throat and i have built it to spin 7k.
I have a build page on instagram too if any of you wanted to follow that. Project Deadpool Silverado
Quick Reply: 5.3 vs 6.2 with PD supercharger
