5.3 10lbs of boost?
Old Dec 7, 2005 | 04:33 PM
slamedboosted&shaved's Avatar
Default 5.3 10lbs of boost?
Hey guys i have a 5.3 with a whipple on it. what would i need to run 10lbs of boost. I'm getting meth inj, smaller pulley and a tune is there anything eklse ineed?
Old Dec 7, 2005 | 05:16 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
do you already have larger injectors and maybe a fuel pump, that should be it
Old Dec 7, 2005 | 05:43 PM
make damn sure you have no kr. you will fry your pistons and/or rods.
Old Dec 12, 2005 | 07:33 PM
low99silverado's Avatar
I ran 10-10.5psi in my 99' 5.3, with meth and no knock. With the boost-a-pump that came with my whipple, I never saw a loss in fuel pressure either so you might be ok with the stock. Never know though.
Old Dec 12, 2005 | 09:00 PM
1SlowHoe's Avatar
Destroyer of Transmissions
What is the limitation of the engine? Is it the rods, pistons, crank?I guess I'm asking, with a perfect tune, plenty of fuel etc, how much boost until something mechanical lets go? A seal, gasket, rod, piston, blower shoots through the hood?
Old Dec 13, 2005 | 07:54 PM
dc96819's Avatar
Maybe 500 on rods and pistons and 800 on the crank
Old Dec 13, 2005 | 08:01 PM
1SlowHoe's Avatar
500 pounds of boost?? Sorry had to do it.
I know many guys on here have to be pushing more than 500 on stock rods/pistons, right? Maybe not?
I'm thinking the 6L might after I get it tuned @ 8-9pounds. If not the HP, I'm pretty sure the TQ will be 500+
Old Dec 13, 2005 | 09:48 PM
EDawg's Avatar
Default bye bye rings
i would buy some good pistons and rings.
LCHEE
Oct 24, 2020 04:10 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
