new fuel set up next week...parts?
what all do i need to put a return fuel on my 05 truck.
1.fuel psi reg.
2.feed line -10
3.return line -8
4.2 340 pumps
5.Y-block for pumps
6.?
i guess i can use my stock fuel rails. and just return for the fuel psi reg.?
thanks for the help.
1.fuel psi reg.
2.feed line -10
3.return line -8
4.2 340 pumps
5.Y-block for pumps
6.?
what is over kill??? i will be pissed off if i put smaller line on and get to 900hp or so and be out of fuel.
the boost ref. reg has a return on it why could i not run new line to the stock fuel rail and return off the reg. back to the tank?
Tin Foil Hat Wearin' Fool
You can but you have to use that cheesy *** connector the converts from AN to the quick release, I had a hard time getting it to seal well on my stock rails so I went to aftermarket rails, it also gives you a way to mount the FPR. Theres no point in running -10 feed with stock rails since the nipple on the stock rails is only maybe 3/8" in diameter.
What aftermarket rails did you use? Was this on the stock intake manifold?
I am pretty sure with the new setup im going to be running out of fuel with the 255 and returnless, so this is my next step. I already have an Aremotive boost ref fuel pressure reg.
Mossyoakglock
07-17-2015 08:30 AM
