Yes it is a blast to drive, everyone says it sounds like 10,000 rpms when I go thru the gears haha I have video of it i jus don't know how to upload it. Those new Mt pro radials are awesome tho that's how I broke tensioner hit 3rd flat on the floor prolly 6500-6700 rpms and pop there went my power steering lol
Yea I thought 8 rib set up how much would all new pulleys run me u know th ed best place to get them? Thanks for the info.
And I will check pully sry guys my Lil boy was up all night I needed a nap this morning haha
Pulley reads 03.300 idk if that is good for 10lbs or not if it's not and I went to a 8 rib set up and 12 psi thing should be a lil more peppy. Not that it's not now.
Probably a 3.3" pulley then. Rule of thumb on most of their kits is .1" of pulley size gets you about 1psi. So a 3.1 or 3.0 should get you there. But I'd look hard into an 8 rib setup. With that much boost, your gonna start running into more belt slip too.
The whole 8 rib set up is about a grand tho. U think I'm at 10 psi with my pully now? I don't have a gauge. But it the HD tensioner will fix my problem may jus do that for now but thanks for ur help
You should definitely do an HD tensioner. It will help a lot. Also try a gates belt as they tend to not stretch as far. The 3.1 pulley should get you where you want to be.
Have you thought about meth injection? |
