4.8 turbo or 5.3 turbo?
#21
Well im deffinately gonna boost the 4.8
I fully agree with you guys, a turbo 6.0 would be alot better than a turbo 4.8. Dont really see why peoplewould think the other way around lol.... I think im gonna turbo it and run it till it breaks like another person said, and in the process have another something on an engine stand waiting
I guess I could see why people would wanna do a 4.8 swap though, it is pretty damn cheap for them
#23
but like I said earlier, it will be in about 6 months because my trucks still in NC, while I just got moved to the middle of the desert
29 palms lol
#26
I guess I could see why people would wanna do a 4.8 swap though, it is pretty damn cheap for themWe're just getting ready to start a 4.8L TT too. That recent Hot Rod article certainly got a lot of people's attention-- that the "weak sister" 4.8 might end up being the most desirable performance engine in the after-market.
There are a bunch of attributes that make it more interesting for boost:
1) Iron block, but thicker walls than any LSx or LQ4/9 motor-- excepting the 5.3 that uses the same block
2) Smaller bore also implies lighter pistons
3) Shorter crank means less stress at the peak load parts of a combustion cycle.
4) Near-ideal rod ratio for high RPM, boosted applications.
If you read Corky Bell's book on Turbo'ing engines, it's eye-opening that the 'peak stress load' isn't when you'd think it is--- and the boost (and back-pressure from the exhaust side) actually REDUCES some key stresses. We kinda came to the conclusion that the 4.8 is the dream date for a boosted LQ/LS motor.
We'll post a build thread once we get started. We are looking at using a pair of GT2871s.
#27
keep the 4.8 trust me you wont regret it we have done 2 4.8 turbo builds with a 76mm turbo and they have turned out better than everyone had expected here are the links to the 4.8 builds
https://www.performancetrucks.net/fo...me-out-485875/
https://www.performancetrucks.net/fo...umbers-486333/
https://www.performancetrucks.net/fo...-turbo-481155/
https://www.performancetrucks.net/fo...-truck-486408/
#28
By keeping the shorter stroke 4.8, you can create more power in the high rpms and keep the torque down(relatively that is), which also helps contribute to the less stress factor.
I don't think you will regret going turbo on either, but I feel the same as a lot of guys and think the 4.8 is the way to go, that's why I chose it for my project car....
John
John
#29
Whoa, those videos are incredible. What kind of boost control are you running?
I love the 108 in the 1/8th run. Wow.
#30
we are barely starting to experiment with a 5.3 and see how much we can get out of it ill be doing a threat once we have results from it
Because I am thinking about doing a similar build on my ECSB
