4.8 with 5lbs of boost....stock tune ok?
Old May 17, 2012 | 12:34 PM
smokeshow's Avatar
Mod with training wheels
Relocation of the MAF alone would mess up the calibration enough to prevent running on the stock tune. You can do all sorts of modifications to a stock tune vehicle as long as the MAF is untouched and it would probably run fine, on the MAF. But putting a turbo in front of it and moving the MAF itself prevents any hope of running a stock tune.
Old May 17, 2012 | 01:13 PM
Silverad0 SS's Avatar
Ok thanks, and I'll be running a rear mount so no under the hood temps, and the MAF will be in the same spot
Old May 17, 2012 | 01:19 PM
smokeshow's Avatar
If it has a rear mount turbo, the MAF is not in the same spot.
Old May 17, 2012 | 03:26 PM
Hmmm... Where does it go then? My kit is still in the box with everything wrapped up, I was pretty sure that it dont get moved?
Old May 17, 2012 | 03:52 PM
smokeshow's Avatar
My point is that if it isn't in its exact same location including original intake piping, the calibration will need to be changed and stock tune will not work. Just because it is the same distance from the intake with different cold side pipes doesn't mean a stock tune is going to work.
Old May 17, 2012 | 03:55 PM
ak2007r6's Avatar
Blowing up a motor is not cheap. Why are so many people willing to risk that??
Old May 17, 2012 | 04:12 PM
nonnieselman's Avatar
for the challange
Old May 17, 2012 | 04:46 PM
A Low Dime's Avatar
13 Second Truck Club
Originally Posted by Silverad0 SS
Not trying to hijack but I got kinda the same question, I should be able to crank an run down the road on 3-4 psi with out a tune for it, I already have a wheatley tune on a stock lq9, and I shouldn't need to change the plugs either?
Wtf. Where do people get these ideas.
I just installed a turbo kit and Im running 6lbs, but I dont want to run the turbo anymore, can I take it off and keep running 6lbs?
Old May 17, 2012 | 04:54 PM
03sierraslt's Avatar
I feel some clarification is in order. It doesnt matter who tuned your truck, where what sensors are, what form of forced induction you have, or even if its only temporary. If you are not tuned for boost then don't run boost, and know that if you do you are taking a gamble on your motor.
Old May 17, 2012 | 05:02 PM
CC05's Avatar
Information here is conflicting with the information over on HPT. I want to answer you, but I'm thrown off. Over on HPT, it sounds like you're already diving in with the tuning yourself, all on stock MAF and stock injectors, but if you're going by what you said here, wait for the tuner to get back. That might sound redundant, but that's my best advice.
