3 bar map sensor for truck intake
Just curious what people have done for a 3 bar map sensor on a truck intake. I've been doing a lot of reading and I can't seem to find much for a truck intake. The motor is a gen 3 motor. Any advice would be greatly appreciated. Thanks.
I have made them before. How much boost are looking to make? A 2.5 bar will get you to 21 PSI.
It'll be right around there somewhere. I'm looking to max out an S475 on a 5.3, so about 800rwhp or so.
The top port is the perfect size for a 3/8 npt tap if you want to run a generic map sensor with a nipple on it. I did that just fine for a while.
How long do you expect a gen 3 5.3 to last at those levels? Serious question, as I'm looking to max out an on3 78/75 on a gen 3 5.3. Figured that I'd bend the rods in this heavy truck before the turbo was maxed.
With the older rods you are just waiting for them to bend at over 600-700whp.
Originally Posted by FFDP
(Post 5391556)
Pretty sure an l33 holds the SBE record right now in a foxbody. Badass lil motor!
Originally Posted by 1969x11
(Post 5391981)
