The 160* Thermostat Thread
How many of you guys are using this and do you think its a necessity to have on a turbo application? What are the benefits?
Well I like it, runs a little cooler at the track for me. You are going to hear the LS engine post to run hotter. Dyno shows me I said me difference. Cooler was better.
Im also wondering it it is necessary to put a 160 in.
Correct me if I'm wrong temp will still be the same it will just take it longer to get there?
160 stat means it will be fully open at 160 and if the cooler system and fans can keep it there it will run 160. But my truck will 175 if I let the fans run more. Like I do at the track.
Whats the factory one open at? 190? Seems like its really close to 200 on the gauge when fully at operation temp.
So I assume you can run a little more timing with colder engine temp?
ive heard if you run a 160 t stat that it should be mentioned to your tuner. is that correct?
Yes, the cooler temp help with spark knock.
Originally Posted by mudmanmatt
(Post 5026315)
Originally Posted by patofdzb
(Post 5026332)
