12 psi what to expect
got a retune from from tuner MECHE member on site . specs on in sig .how much rwhp you gays think i am making now on 12 psi pump gas (9.1 compresission) 16 deg timing on pump gas no meth . going to make some pulls on dyno in jan 2015 .want see how close results will be .thanks again to trick performance and tuner meche (garret)
I dont see anything about the heads or cam you have... but 600ish?
I'll guess 570-580
head & cam
(Post 5262741)
Figure out where you are on the compressor map at 6000rpm and multiply the mass flow in lb/min by 10 and that will get you close.
Trap speed at a track and your weight will tell you much better what kind of power you are making than a dyno will. |
600-650 I would guess. Darnie made about 600 on a 5.3 p&p heads tr220 cam and 12lbs. His truck is pretty wild for what it is so I would guess you would make a tad more.
My set up made 578/550 on 12psi on a dynocom. Not sure if that helps at all.
rwhp
Originally Posted by gamble686
(Post 5262944)
Is that the TCI valve body or complete tranny or does someone else make one now? That has to be a nice upgrade! I know this 6l80 is way nicer for a driver than my 4l60s or 4l80 ever was.
tranny
Originally Posted by ZO6Ted
(Post 5263069)
