08 RCSB 4x4 5.3L 14-15 lbs of boost?
Old Apr 21, 2014 | 07:04 PM
400ss's Avatar
Default 08 RCSB 4x4 5.3L 14-15 lbs of boost?
im working on my 08 5.3L rcsb 4x4 5.3L 4L60E.
have this parts:
on3 turbo, air to air front mount intercooler, 50mmBOV 50mm WG. 80lb siemnes injectors, double intank 255 walbro, corvette fuel filter regulator on the rail. water meth injection.
the engine is completly stock, will it hold 14-15 lbs of boost?
does the parts i have will support it??
planing on swap my trANS FOR A 4l80e.
IM WORKING ON IT I WILL ADD SOME PHOTOS.
Old Apr 22, 2014 | 01:16 AM
La Grey 1's Avatar
i would change the trans first why let the one you have die might as well sell it while its working, and i am in the same situation as you and several have recommended good valve springs at least when going over 8-10 pounds i have been on 8lb and no issue and have read some have done 12lb but i prefer to have it on 6lb so i wont risk it while i gather for a cam kit arp bolts and head gaskets....
Old Apr 22, 2014 | 10:29 AM
Blackpanther99's Avatar
Get a 4l80e swap asap.
Upgrade to Ebay or ARP head studs and all bolts. Gap rings for boost.
Im guessing youll be on pump gas right?
Old Apr 22, 2014 | 10:43 AM
Choda's Avatar
Im at 12 on stock parts. i think its at its limits or already over them. Its held 15 but that was a WHOOPSIE
Old Apr 22, 2014 | 05:27 PM
TV559's Avatar
That's what I plan in doing. Buying a 4l80e, shift kit and converter then do a turbo setup. No sense in buying a turbo kit when the trans will go out pretty quickly soon after.
Old Apr 22, 2014 | 07:04 PM
03sierraslt's Avatar
The engine should be ok at that level with meth and a good tune. The trans is another story, do that swap first before you break the 60E. I would upgrade your valve train for those boost levels, stock springs dont like much boost.
Old Apr 23, 2014 | 11:45 AM
400ss's Avatar
THanks everyone, i just buy a 4L80E, stock converter for the moment, will start installing it, i already read what it needs to be done, retune, rewire harness, and some others mods.. I have a 6L80E too, im sure i can successfully install it, wich one u think is better?
About the Fuel, 80lb siemens, and twin 255 walbros, and corvette fuel filter/regulator will be ok for 14-15 lbs?
thanks to everyone now i know is better if i upgrade those parts:
RING GAP: what size?
VALVE SPRINGS: Wich ones?
ARP HEAD STUDS, BOLTS
HEAD GASKET: Wich one?
Old Apr 23, 2014 | 01:45 PM
Stay with 4L80e. Less headaches.
Old Apr 23, 2014 | 01:47 PM
LS9 head gaskets.
Brian Tooley double springs.
Arp heads studs and bolts.
Old Apr 29, 2014 | 07:56 PM
Choda's Avatar
I've been told the stock cam hates anything more than 12 psi. Sure the new springs, studs, fuel, etc.... Will take it but the stock cam hates it and is why cam upgrades, esp w boost, are very common and deliver serious results. Only reason I haven't done all that w mine is because I am trading it in on a new one.
