Trick to STS swap
3 Attachment(s)
So I finished the swap and headed to the dyno today. I still need to fix a few issues and work on the tune a little but I got some comparison numbers. I have attached the dyno sheets for comparison. The STS kept up better than I thought but look at the power under the curve with the faster spool time.
Low boost off the wastegate spring STS - 7.75psi Trick - 6.75psi STS - 405/419 Trick - 400/430 More boost STS - 12psi Trick - 12psi STS - 544/571 Trick - 559/622 Final pull STS - couldn't load past 12psi on the dyno Trick - 14.5psi spike and settles to 13.5psi Trick - 610/660 I need to figure out why the boost is dropping 1-1.5psi after it spikes but I'm pretty happy so far. The uncorrected numbers today were 627/677 so it feels very good on the street. Also the last pull was run #104 on this stock Lq4 and it keeps on taking a beating. I might switch to 3bar and see what it will take. |
Glad you got it running! Nice numbers, about what I would expect. The rear really doesnt give up any pk power. Which AR housing were you running on both setups?
Originally Posted by stock48
(Post 4447346)
I was running the 1.15 housing on the STS and the .96 on the Trick. I picked up about 15-20 with the 1.15 housing on the STS kit so it would have been cool to run that on the Trick. |
good thing about the sts is the IAT's are good. which is were a good bit of power can be made
nice numbers, i would have thought the front mount would have made alot more than the rear mount, guess they arent so bad after all lol
Originally Posted by charcold-bowtie
(Post 4447353)
love ur trq its up there on my procharger build i made 627rwhp and 549rwtq
how much timing did u have i had 17* ? |
Originally Posted by Most Hated
(Post 4447364)
This is some great comparison info!! Thanks for posting this up. There's alot more under the curve power that was lost from the STS than I would have originally thought! Very cool! :thumb:
Originally Posted by Spoolin
(Post 4447388)
