Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Baby cam LQ4 dyno...
Old 02-14-2015, 10:57 AM
10 Second Club
Default Baby cam LQ4 dyno...
Less than I expected, 2nd gear pull. Ran 14.321 @ 98.02 a few weeks ago.
Old 02-14-2015, 11:01 AM
Formerly ScreamingL
George C....'s Avatar
thats low, my stock LC9 made more to wheels
Old 02-14-2015, 11:16 AM
10 Second Club
Yup, but the drag strip dyno doesn't lie.
Old 02-14-2015, 11:18 AM
Formerly ScreamingL
you referring to times in your sig of mid 14s?
my old LM7 back in 03 ran 14.6@94 mph stock with muffler and air filter so a lq4 should easily go faster stock form
LQ4s makes more torque then that in stock form from my experience
what are the cam specs
Old 02-14-2015, 11:25 AM
10 Second Club
My LM7 went 15.6 @ 87 stock. The cam is 202/216 @ .050, .525 lift, 112 LSA.
Old 02-14-2015, 11:38 AM
Formerly ScreamingL
Where are you located that's 4.8 times you posted unless you're in Denver or similar
Old 02-14-2015, 12:56 PM
10 Second Club
Orlando, FL
I post my results good or bad. My next task is to get an accurate weight on this thing. I'm guessing around 4600 lbs w/o driver.
Old 02-15-2015, 10:04 AM
brewster240's Avatar
my 01 rcsb with lq4 with 243 heads and ls2 cam, 3.42 open diff runs 14.0 and put down mid 320 to the tire.
on a shitty tune running out of fuel up top.
Old 02-15-2015, 10:27 AM
Fast355's Avatar
4L80E 2nd gear pull unlocked will just hurt your feelings in a dyno pull. Numbers would be 10-15 RWHP higher with a locked converter and probably equally higher in 3rd gear.
Old 02-15-2015, 01:53 PM
10 Second Club
It was a free dyno day, grew tired of people asking what it makes for power. Now I can hand them a graph. I requested a 2nd gear pull because I didn't want to chance the driveshaft exiting and destroying everything in its path. I have factory 3.73s with 18X9 Billet Specialties wheels and 275/60-18 tires. (31" tall) My wheel and tire combo isn't ideal for the dyno or dragstrip.
This is my daily driver/weekend work horse. It has power everything, runs on 87 octane, etc. It won't shatter any records, but is doing everything I need it to do - while being more fun to drive than the stock 5.3/60E.
Quick Reply: Baby cam LQ4 dyno...
