L33 BORG 80/83 Dyno
05 L33, Tick stg.2 boost cam, borg 80/83 T6 cast, unlocked, 19.5 psi 93 and 50/50 meth, 10 degrees. 767 rwhp. Dyno would not load, had to brake boost at 3k to 2lbs to get party started, so tq was 930ft lbs lolhttps://cimg7.ibsrv.net/gimg/www.per...7d92606718.jpg
Damn jweb. ONLY. Lol Great job. |
:) not as responsive as the 4.8 set up, need to get it to leave harder.
What happend to the 4.8 setup? No studs or gaskets on the l33?
We turned that booger up to 25 psi, that was a 03 4.8, stock but cam and springs. My first pass at 25 psi, it spun a 1.70, then peddled, went 6.73 at 103, 2nd pass it let go. Looking over log, meth quit at 50mph, and iats skyrocketed, piston then rod, or rod went first , not sure. Ordered a L33 from a junk yard in North Dakota, cleaned it up, regapped the stock rings, did gaskets and studs. https://cimg2.ibsrv.net/gimg/www.per...c6aac12f7d.jpg
Best pass remains 6.61 at 104 and 10.39 at 128.9 with 4.8 s369 combo at 20lbs. I ran new set up at 17lbs and went 6.72 at 101.5 8th. Didn't hit 17lbs until 1-2 shift, so working on getting boost to come in faster, and we turned it up a couple lbs. I did cut a 1.50 60ft leaving off 4lbs with new set up, so pleased with that.
Originally Posted by fastjweb
(Post 5442119)
And that ear missing looks familiar. |
Wouldn't make full boost on dyno without brake boosting?
Not bad!
Turbos are very tricky to load on the dyno, so that's not surprising. |
Mustang dyno, load cell was wired up wrong. It would not make full boost by redline, that was the only thing I could think of to try. Dyno has since been fixed, but haven't been back.
| All times are GMT -5. The time now is 10:01 PM. |
