Heads cam intake 6.0 on 10# What will she make?
My set up is
lq4 short block texas speed 2.5 317 heads 224/228 114lsa camshaft fast lsxrt intake kb front mount kit 76mm ebay turbo 3.5 down pipe fmic stock tb 60lb injectors walbro 255 intank the plan is to tune it on the 10lbs She is at the tuner right now i should know the numbers later today or tomorrow. The person who guesses the closest gets a cookieswingit Well flaco did his magic and we were having some waste gate issues couldn't get it to hold 10psi. it would peak and then fall off to 6.5lbs so at 4500rps it made 547/549 it would lose power from there. I will be changing the spring tomorrow and crank it to 12lbs and she should be 630ish |
625rwhp 690rwtq
My 6.0 put down 625/660 on 10psi. I'm sure you'll be right in that range.
I would be happy With 600.
looks like im going to need a 80E faster than i thought.. |
Ill say 675/625. With those heads, cam, and LSXRT it should be a screamer up top!
Good luck! :thumb: |
Originally Posted by black00chev
(Post 4917959)
Good luck! :thumb: how much can the stock bottom end take? |
Depends of who you ask! I feel like Ive seen anywhere from 800-1000 max.
Anyone else have an guess?
Originally Posted by black04silverado
(Post 4917973)
I hope your right!!
(Post 4918096)
there is one that we know of thats putting down about 1100-1150 to the wheels, but on a stock intake, stock heads and a baby cam :secret2:
