Got the D1sc dynoed
#43
Originally Posted by peppersac
I have a 4 inch pully with a d1sc and I only hit 10 lbs at best. I am getting robbed.
you may be getting some belt slip
#47
I hate to hear you blew a piston.
That is however ,way too much boost for a stock 5.3. I would look into a different builder/tuner myself.
I think you could have hit the same hp with 9-10 psi boost easily, you could have been more aggresive with fuel and timing with less boost.
That is however ,way too much boost for a stock 5.3. I would look into a different builder/tuner myself. I think you could have hit the same hp with 9-10 psi boost easily, you could have been more aggresive with fuel and timing with less boost.
#48
Originally Posted by ranwalk
You may want to check some things. I see 13psi peak around 6300 rpm with a 4inch pully. This is on a 6.0 with a small cam,minor head work,long tubes,no cats,3inch y-pipe and 3.5 inch single exhaust dumped.
Or a small leak
I hit 10psi around 5800 rpm and then it shifts. What can I do to see if I have some belt slip?
#50
Originally Posted by Blown06
Not really sure how I could have run less boost. Does anyone make a pulley for the D1sc that is bigger than 4".
