Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
2nd or 3rd gear
Old Jul 25, 2006 | 01:47 PM
dirt track racer 81's Avatar
Default 2nd or 3rd gear
what gear do most of you guys dyno your trucks in?? ive always done 2nd gears..6600 rpm in 3rd gear would be too much mph for me
Old Jul 25, 2006 | 03:08 PM
KySilverado's Avatar
3rd gear is 1:1 and should give the most accurate numbers. I've done one pull in 3rd to 5800 rpm. It was within 2hp of the 3 other pulls I did in 2nd.
Old Jul 25, 2006 | 04:27 PM
RoosterMcCandles's Avatar
They should be done in 3rd for the most accurate reading because of the 1:1 ratio but for many trucks, that does turn out to be too much mph...
Old Jul 25, 2006 | 05:17 PM
on our mustang dyno from 5500 on up it seems to take for ever..so we just do them in 2nd on the trucks..
Old Jul 26, 2006 | 11:52 AM
Toe's Avatar
Toe
If you can remove your speed limiter then a 3rd gear is the way to go. At least on a Dodge I saw 15hp more in 3rd then in 2nd, but topping out at 6100rpm in 3rd it was at 122mph, which can lead to bad things like drive shafts over flexing if they aren't designed to handle those speeds.
Old Jul 28, 2006 | 12:08 PM
agreif's Avatar
Do whetever gear will keep your driveshaft and tranny in tact. 2nd gear will give you slightly lower numbers, but will keep your DS from going if you have the 1 piece.
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
Oobray
Jun 13, 2022 03:38 AM
1slwgto
Aug 16, 2015 06:40 PM
lxcoupe
Jul 14, 2015 10:14 PM
