Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
12 Second CC 5.3 hit the dyno today!
Old 04-11-2015, 08:39 PM
vettelovralexand's Avatar
Default 12 Second CC 5.3 hit the dyno today!
Results: 515 hp and 487 lb-ft only pulling to 6k!
They started to fall off because we were running a lot of times back to back. The truck's stock 60k all terrains couldnt hook on the dyno at all. Wound up with 600 lb in the bed and double strapped with 25 psi in the tires to make the pulls we got.
Old 04-11-2015, 09:08 PM
07bluelbz's Avatar
Very nice.
Old 04-12-2015, 09:19 AM
Choda's Avatar
It ran a 12 what?
Old 04-12-2015, 09:31 AM
Resident Retard
BlackGMC's Avatar
Mods?
Old 04-12-2015, 10:21 AM
12.700@109.48 at IRP on 4/1.
Mods: Roush TVS1900 with 10% overdrive lower pulley, 219/234 BTR specd cam, PRC stage 1 LS6 heads w BTR platinum springs with Ti retainers, Kooks 1 7/8 headers with catless y pipe, factory NNBS flex fuel pump, and 6.2 flex fuel injectors. Tuned for 93 octane by Blackbear performance.
Old 04-12-2015, 11:27 AM
Formerly ScreamingL
George C....'s Avatar
thats bout right for ET/MPH for power
i made 540/550 Sae and trapped 113mph also with a small blower on a 53
how much boost
Old 04-12-2015, 03:29 PM
oakley6575's Avatar
OP, sounds like a solid set up. Any pics or vids of the truck?
Old 04-12-2015, 03:57 PM
By the look of the truck you wouldnt know that the truck had anything but corsa exhaust done, so just picture a white z71 crew cab with that and a 1 inch front level from bilstein 5100s and youve got the idea.
I have a video in my thread here: https://www.performancetrucks.net/forums/drag-racing-139/new-pb-2009-tvs1900-h-c-ccsb-12-second-crew-cab-536724/
I am still waiting on the dyno videos.
Old 04-13-2015, 06:48 AM
Here is the video of the highest power run:
You can see by the graph in the video that it had already done 2 dyno burnouts and they had cranked the straps down to get a good pass in. It did a burnout again the next run before we added weight and dropped tire pressure, but it was already heat soaking. Enjoy!
Old 04-13-2015, 09:40 AM
Vortec350ss's Avatar
Great numbers!!! This is awesome!
How much total boost are you seeing? Man once you add meth and a smaller upper pulley its going to be even stronger! You will be amazed at how much those mods can help.
Quick Reply: 12 Second CC 5.3 hit the dyno today!
