need rear suspension torque specs
u bolts, shackles and the front hanger. need them all. thanks for any input!
Leaf Spring Mounting Nut
200 N·m 148 lb ft Rear Leaf Spring Shackle Nut - 1500, 2500, 3500 95 N·m 70 lb ft Rear Shock Absorber Upper Bolt - 1500, 2500, 3500 115 N·m 85 lb ft Rear Shock Absorber Lower Bolt - 1500, 2500, 3500 115 N·m 85 lb ft Rear Spring/Hanger Bolt 50 N·m 37 lb ft Rear Spring Stop-3500 50 N·m 37 lb ft Rear Stabilizer Shaft Insulator Nut - 3500 32 N·m 24 lb ft Rear Stabilizer Shaft Link Bolt (Frame Side of Link) - 3500 95 N·m 70 lb ft Rear Stabilizer Shaft Link Nut (Bar Side of Link) - 3500 53 N·m 39 lb ft Rear Suspension Jounce Bumper 32 N·m 24 lb ft U-bolts - 1500 100 N·m 74 lb ft U-bolts - 2500/3500 160 N·m 118 lb ft phump |
Be sure to torque the leaf springs/shackles at static height with normal weight of the vehicle over them. Prevents bushing binding, and affects ride height too.
thanks for the help guys. new springs with an overload leaf actually lowered my truck even more! guess i need 2" lift shackles now?
