B&M Hi-Tek Deep Trans Pan for 09-17 Ford F150 w/ 6R80 Transmission
Application: Fits 2009 to 2017 Ford F-150 and similar models with a 6R80 automatic transmission. Will Not Fit Mustang
Description: B&M's Hi-Tek line of Deep Aluminum Transmission Pans are constructed of thick A356.0-T6 cast aluminum and feature a durable black anodized finished. Designed to fit 2009-2017 Ford F150 trucks with the 6R80 transmission, these finned deep trans pans significantly increase the fluid capacity and dissipate heat much faster to prolong the life of the transmission and related components. Additional features include an engraved B&M logo, drain port, temperature sensor fitting, magnetic drain plug and complete hardware and installation instructions.
- Black Anodized Finish
- Additional Fluid Capacity
- Fill Plug and Magnetic Drain Plug
- Durable A356 Aluminum Construction
- Lifetime Limited Warranty
Please call 707-544-4761 or visit www.bmracing.com for additional application and product information.
Considering adding a B&M Hi-Tek Trans Pan to your 6R80 equipped Ford? Steve is here to guide you through the installation.
