Rear Brake calipers
Rear Brake calipers
I was going to swap rear calipers a few years ago but I was able to do some grinding to fit my 16" wheels.
Now I am ready to replace them but my issue is the banjo bolt coming straight out towards the rim. The banjo bolt actually rubs the rim so I have been looking for some calipers that have the banjo bolt coming in from the side (along the line of the axle) if that makes sense. I HAVE HAD NO LUCK.
Anyone have the same issue ? Any answers ?
Pitt
Pitt
Are you going to 15" wheels?
You can use the early 2000 S10 calipers on the stock rotors/brackets and will likely still require grinding depending on wheel fitment.
Or you could do the GMT400 4wd front rotors/calipers with 1320wheels brackets and remove all the parking brake hardware for more weight savings.
Hit Man X
13
05-21-2004 10:16 AM
Chingon
21
03-13-2004 12:02 PM
