Practicing with REAL street tires.
So our local track is running a TRUE street tire race in a few week. Deal is you have to drive thru the gates, insured, and run Non-drag radial tires. Winner takes $500.
Well, I figure a couple test runs is a good idea. Lets just say this going to be tough, real tough for the 500+HP guys to make this happen. I tested launching at 2500, was cutting 2.0 60', but it was around 330 foot area when I started laying into past 50% that fun started lol. I'm running NT05's on the rear. 200 tread rating. Managed a couple high 7 second passes. I think if I can cut a mid 7 1/8th and good light I "may" have a chance at it. True Street Tire Fun - YouTube |
Ha sounds like you left idling to keep from spinning. That should be one heck of a challenge for you. I know mine which is mostly stock was spinning bad on street tires, I couldn't imagine with the power you are putting down.
I know a guy that ran an 11 flat on 20 inch radials, but it wasnt posted to the internet, aka didnt happen.
What are the acutal specs? I see you say non drag radials( which I think he was on)? So im assuming they would toss them out, even at 20 inch wheel specs? |
Thats when the real driver in you comes out. Good luck!
This is where 4wd would come in very handy. I tried to run on street tires one time at the track and it was a FAIL. |
Your truck is a BEAST, and your track isn't closed for the WINTER. I hate you. :gruffy:
Originally Posted by AKlowriderZ71
(Post 4793785)
Lol, I'd launch in 4x4 with my studded tires. Wonder what my 60' would be?? :)
Give it a few shots with not doing a long burnout like that, just spin the hides over a few times to clean them.. Truck is a beast for sure
(Post 4793788)
(Post 4793789)
I found that when I did a longer burn out on my stock tires it was actually hurting me more than helping. I just pull up and do a two count and then roll out of it. Seems to work best so far for me |
You need to find a good ole boy to let you borrow his 16X10 's . Bunch of contry folk got em round here. You might do better dialing the boost back some...Good luck man!
