Got the silver bullet in the 10's!
I have been chipping away at the E/T and waiting for cooler weather. well the cooler weather finally made it to arizona and my truck is taking full advantage. have done slight weight reduction (lighter front wheels, removed front pass seat/console). weighed in at about 4750 with half tank of gas. did a couple of test passes on lower boost (only teched for 11.5). on my 10psi setting i was only hitting 8.7-9.0 lbs boost for some reason and ran a 11.55 and a 11.7x. last run i turned it up to the 12.0 lb setting and let her rip. banged out a 10.905 @ 122.86 with a 1.592 sixty footer. i forgot to check my max boost i hit and forgot to datalog it too so not sure what psi i hit but based on my previous runs i may have only hit 11psi.. so maybe i can go faster??
_zblee
_zblee
