This combo good enough for 11's?
Well I have a 2002 extended cab short box silverado and am really hoping to bust into high 11s. Just want to know how hard it will be with my combo. Mods
6.0 , isky 212 cam. Kb turbo kit with magnum t76 .96 ar 3.5 down pipe. No meth yet on 93 octane. Gonna run 10-11# spring. 4l80e/ stock converter, 4.10s for now but will be swapping to 3.73 or 3.42 before to long. I have a nitrous plate kit on it for use out of the hole with about a 75 shot till about 6-7 psi if needed. I have caltracs and hoosier 28in slicks also. What yall think? |
If you can get traction, and the tune is perfect, you can get there I think.
You need a converter bad!!! Nitrous will help but you will have shitty 60 ft. times and that doesn't make a good foundation for a strong 1/4.
Without you have a chance, with you should be there with out a problem. |
Cool. I usually have good Da too. Elevation is only about 300 ft but on some cold nights iv looked and its been negative Da before.
Originally Posted by custm2500
(Post 4843337)
Spray a 150 out of the hole and cut it off earlier to make up for that stock converter.
Very possible sir
You are there unless you are really heavy. these trucks vary so much...
i dont see why not and mauybe a 100 shot to make up for the lack of converter
I bet with practice launching you will get what you are asking for.
I like 12 psi myself, feels so much stronger than 10psi. Brake stalling works best for me. |
