6 speed 6L low 10s
6 speed 6L low 10s
Customers truck local here in baytown, tx
Recently ran low 10 at 139 mph
Engine is a iron 6 liter with l92 heads, jarrett cam, s476 from FI t4 96 turbine wheel IIRC, head studs, ls9 gaskets, holley hi ram, generic kb style hotside.
6 speed is built by the owner, has a circle d converter 3600 multi disc, full weight with center console and escalade interior, eboost controller, factory pcm for tuning.
Has 3.23 gears and 30" tall tire, boost is ramped up via an eboost set up at 20 psi. Converter is locking up at 103 mph. Wheels are weld s77.
Timing is at 15* and is at .8 lambda, e85.
4.027 2.364 1.532 1.152 0.852 0.667
So theres no true 1:1 gear but trans keeps burning up if it goes into 5th with converter locked or unlocked owner wants to go to a 3.08 gear so he can stay in 4th with converter unlocked a little longer and lengthen the life of the trans
thanks guys!
@blown, yea the truck spins on 1st, ill see if i can upload a video.
@fillpot, fronts are 17x7, 28" tall tire rears are 15x10 with a et pro 30" welds s77, and yea i tune a lot of turbo stuff here in houston, TX. I don't do the installs, the shop I tune for handles that.
