more hemi bad news
Go with the 6.1 crank and toner ring. You'll get a forged crank and a better toner ring in return. There has only been one truck with toner ring failure that I know of that didn't have a 6.1 cam and/ or an underdrive pulley. But he did have his superchips at over 6100 rpms.
Below is a pic of the 6.1 crank and toner ring next to the 5.7. it's obvious where the weakness is, between the spaced bolts, and that's where the failures are coming from. Stu, DTW, has designed a beefier 5.7 toner ring but if I were you, and I did this to, I'd drop a forged 6.1 crank in with better toner ring and not worry about it again.
And you can go a step farther like I did, add the 6.1 forged crank with better toner ring, have the underdrive pulley balanced on the rotating assembly, add a set of forged rods and the ross pistons and then go have a ton o fun. LOL
we havent had any problems so far at the dealer i work at with those rings. if you can then def. change to the 6.1 crank. looks 100 times stronger.
btw is the 6.1 crank the same stroke as the 5.7? are they just boring them out or what?
what is the difference between the 5.7 and 6.1 crank? is the stroke the different? how much heavier? does it bolt in the same? also will a 6.1 liter short block work in my truck as far as motor mounts, heads, tranny, etc? i talked to the guy that makes the stronger toner ring today. he makes it out of crome moly not stainless, and it is designed to replace a 04-05. i have a 03 and it is different, go figure huh.
This actually needs to be made a sticky, and I believe I'll put it there. A lot of have been saying......"don't turn the 5.7 to 6100-6300 RPMs and almost everyone that has with a few good mods has shattered the ring. Any of you all out there need to consider this post in your best interest. The 5.7 is strong, and it is a durable engine.............but they weren't designed to turn 6+K RPMs leaving every stop light you take off from, it brings out the weak link when we constantly turn them this hard on a normal basis, and this happens to be the "weak link."
eabigrick,
sorry to hear about your troubles, I would recommend balancing the assembly if you change the crank to the 6.1..... as the balance has to be different. After balancing many engines, even stock ones it is surprising how far out they can be...
TJ
TJ
Here is the link in HTC for the custom toner ring http://hemitruckclub.infopop.cc/grou...2/m/4870055214 which could be an option if STU is gonna mass produce them.
Look at this link too http://hemitruckclub.infopop.cc/grou...2/m/3930083514 for more on the DCX performance 5.7/6.1 crank option.
Personally, I am gonna go with the either of the forged cranks and possibly some 6.1L rods with forged coated pistons....
So mopar performance has a 5.7 crank.
Pics are from Uniball on DTW from this thread.
http://dodgetruckworld.tenmagazines....mance_57_crank
It looks just like the 6.1L crank. Art at Henson motors in Texas has them. I think I am going to pick one up, won't install it right away as I am low on cash, but I'll try to pick up some other parts too like rod's and pistons. I think he's asking around $600 for it.
Originally Posted by FogleMotorsports
anybody got the part number for that crank. i might can get it cheaper
Also post up if you can/want to distribute some! I would be very interested as the line with Art is long and I am at the the wrong end...
