6.4 Power Wagon BOOST ?
Not much RAM activity here on Performance Trucks dot ......
2018 " Classic" 6.4 PowerWagon, Nicely geared axles, Locker, decent suspension, pretty nice for a modern pickup truck: Only needs a bit more low end torque to be fun. Question How does one go about BOLTING ON 7 or 8 PSI manifold pressure to one of these little 392 truck motors ? I see Magnuson for the cars, but why no superchargers listed for the Pickup Trucks ? Any one know of a Whipple, Kenn Belle or Magnuson 'charger installed on a 6.4 Truck motor ? Can the factory PCM read and respond to a TWO-Bar MAP sensor ? How much flow can the stock 392 HEMI/RAM fuel pump support ? Anyone attempt to unlock a STELLANTIS PCM ? HPTuners credits work on these ? :burn: . " Help SPEND MY MONEY ! " Thanks.. |
you mean like the factory TRX trucks?
yeah, like TRX- except with the 6.4 Liter displacement, and 3/4 Ton axles, but like the TRX. any blowers that fit the 6.4 Liter intake ports ?
i know procharger makes a truck kit... but that won't do nothin' for low end.
have you called & asked magnuson or whipple if they make truck-spaced accessory drives for their 6.4 kits? |
my 2018 is tuned - never looked into if the gassers use a different PCM or not, though. 2018s need a security bypass cable for OBD port interaction.
| All times are GMT -5. The time now is 03:40 AM. |
