LC9 engine swap 70 C10
Planning a LC9 swap for 70 C10. Read that LC9 is a truck engine and would have small block chev v8 size connectors for radiator hoses.
Can anyone confirm this? Would save a bunch on buying LS type conversion radiator. Thanks |
I thin you mean lQ9, but yeah your old radiator should work. Both heater hoses go to the water pump, you can use the stock upper hose for a 5.3/6.0 engine and it will reach and fit pretty well. I used an adapter to reduce the heater hose outlet on the stock radiator for the steam vent hose from the new engine, this was all on an 82 silverado.
| All times are GMT -5. The time now is 02:59 AM. |
