how do i remove an ignition cylinder from a 94 C1500
Old Mar 7, 2011 | 08:20 AM
03chevyroyce's Avatar
Default how do i remove an ignition cylinder from a 94 C1500
a guy at my work wants me to replace his ignition lock cylinder due to age and the key is worn down. how do i get this damn thing out?
Old Mar 8, 2011 | 10:28 PM
bowtieguy79's Avatar
Go and get your self a cheap harbor freight steering wheel/column kit.
http://www.harborfreight.com/steerin...set-42031.html
Remove the steering wheel, then use the kit to compress the column spring down. Remove the lock ring and then slowly take the spring loose. Once you are in the column that far there is a torques head screw that holds the tumbler in the column. Take it out and use the key to remove it.
I know I have not used proper terminology but feel this can get ya close ; )
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
