94 chevy pickup swap
I need your feedback and opinion. My friend asked me want to know if it is worth to swap from older 350 5.7 to 5.3 GEN3. How hard it will be?? What about wiring harness, Is there something plug and play? Can you help me out before I can decide what to do with my friend truck im helping him out. His truck is 94 Chevrolet Silverado cab truck
To me it's worth the swap. The TBI motor in his 94 is a giant turd, maybe 180-200hp on a good day. The LS swap will hands down be faster, better to drive and better fuel mileage.
They sell motor mount kits and likely wire harness adapters to make the gauges work but that would be some research on your end and for your friend to do.
You might need a matching transmission aswell, not sure if the older 4L60e's will work with the stock LS computer/wire harness.
Being a 94 you have to make sure the 4l60 is a 13pin not a 11pin. other than that just like jamie said, some adapter mounts, fuel pump and a harness... its a awesome swap for a c/k truck
If I recall, I read that the older 4L60E won't work with an LS computer. I've got a '94 with a lightly modified 4.3L and I will eventually swap the engine since its getting up there in miles. But since your friend already has a 350, I wouldn't change it for a stock 5.3L. Has he done the basic TBI modifications? They made a difference in my 4.3L, a 350 will be even better off.
How do you guys make your factory tach work? I've got a 1993 I'm finishing now and the tach and speedo are about all I have left it figure out. I think I just need to put some T taps in the trans speedo output to get the speedometer working but I can't get the tach to register anything.
