6.0 & 2wd 4l80e into OBS: Header Questions
I am almost done doing everything I can before I actually try to fit it all in.
I was going to order the Schoenfield Conversion Headers.... But then I read b/c I am going 2wd instead of 4wd...I can use NBS headers... My truck was orignally 4wd but I ditched the transfer case and front drive shaft. What is the best Long tube header out there for a decent price? |
Do you have the torison bars still in there?
yes, I still have the torsion bars in there.
I test fit a set of 99-06 headers on my 89 with the 5.3 in it. Wouldnt work. They hit the frame before they would even sit flat on the head.
You might be able to use a 4th gen F body header. |
shoenfelds are the only ones i have found
Thanks ordered the schoenfelds and sending them off to get coated thanks!
Originally Posted by gagliano7
(Post 5013343)
Well today is Friday aka pay day and I can't find the *uckers!
I only came across there 2wd models! YELP! & any have access to a wiring diagram for the ls swap to 411 PCM? |
They only make 2wd ones. If you take the front diff out you should be ok.
