P2653 p003a
Getting P2563 code and a random intermittent P003A code. Today the CEL went off, which interestingly enough it went off last week on Friday as well albeit in the morning. I believe the solenoid is stuck and causing the turbo to confuse itself. I took a video of the commanded vs actual vane positions and they seem to be working well based on something I saw the other day on how they are supposed to function. My working theory is that the solenoid is gummed up, tomorrow I will pull it and get it cleaned up.
Here is a video of the commanded vs actual, sorry for the shoddy camera work. mods change title to say p2563 pls and ty |
Do you see at 2:32-2:33 when everything goes to Zero and you still have 78%.... That's what pisses the computer off. I saw it at another point earlier to when it was around 25%
https://cimg8.ibsrv.net/gimg/www.per...7ab2dd9e1f.jpg |
So what the solenoid just can’t keep up? I would imagine (using my imagination here) that if the vanes were sticky then the whole time it would be off.
Around 2:46 it goes low and you can see it still has voltage when commanding 2% and shows 3% actual.
https://cimg5.ibsrv.net/gimg/www.per...b859395eca.jpg |
Originally Posted by shakenfake
(Post 5515852)
Those floor mats really suck... You should find some nice OEM ones.... :thefinger
https://cimg3.ibsrv.net/gimg/www.per...87820a3497.jpg |
The only rational cure is to pull that variable geometry witchcraft offa there, and go Compound:
S369 Into an S480 should about get ya started. |
The ecm will command a vein sweep every now and then to keep the controls mechanism from getting sooted up. That's why a lbz with an exhaust and no lb7 idle will make the whoosing and harrier jump jet sounds at idle occasionally.
@smokinlmm I need an exhaust lol but that has to wait until I figure this nonsense out
Got a 3.5” Borla XR1 laying around I’ll send ya if you just want to get rid of the muffler.
