8.1L Suburban Manual trans swap
#41
My point about the manual trans and changing the rear gears is I can still have superior starting gear with the NV4500 5.2x3.21 starting, far better than 3.73 or even 4.11x2.48. Then if the 3.21 is too low, especially towing, for the o/d I can simply down shift into 4th and be at 1:1.
We threw all the tools, spare parts, floor jack, spare tire/rim etc. in the rear of the loaded expedition and got out of there. Yeah, we realized our error and pulled over and moved everything from the back of the expedition into the sub. It was better, but still squirrely over 55. Also more evidence that my speedometer is off.
I know there are two different NBS tahoes in here that have the NV4500 swap. One responded and not sure if he has the 2wd or the 4wd, or if that even matters. I think one of em needed the slightest massaging on the trans tunnel, (but only to give some transmission (case) shifting clearance).
The NV4500 came behind the 6.0, 8.1 and 6.6 diesel in the 2500 and 3500. The 6spd was only an optional upgrade.
I've got a NV4500 out of a 2000, (with the lower top) sitting 50 ft away, if measuring anything on it might help.
the only big blocks or diesels that had the NV4500 were OBS (454 & 6.5) and dodges (v10 & 5.9 cummins); never was paired to the 8.1 or duramax from the factory due to torque input ratings (not that it couldn't actually handle it, though).
I'm still several months to a few months from doing this. I'll wait until the weather gets cold in December/Jan when its in the 60s. I did just find a 1995 NV4500 from a 10,000 mile truck complete with bellhousing and hydraulics for 1000.00. I also watched a youtube video on rebuilding them. Doesn't seem too difficult. I've rebuilt Muncies and it seems like pretty much the same process. Just slightly bigger gears and clips.
It would be like finding a needle in the haystack to find a 6.0 with a nv4500 at auction. They didn't make many. That would be such a huge find for me as I have my Silverado with a 4.8l that has some mystery vacuum leak. Finding a 6.0 for that and a nv4500 in one shot would be nice. Plus all the other donor parts I need.
also, you'd still want to change the transmission lid to the OBS version to make your install easier.
#42
The 8.1 cargo van the dealership owned that I drove for 4 months years ago averaged 14 mpg. It was a standard wheel base with 4.10 gears. They always made their drivers keep a log of mileage driven daily and fuel pumped out of the tank on site. Loaded down 8.1 van got 14 mpg in mixed driving, whats hard to believe about a much lighter Tahoe with taller overall gearing (equivalent to 3.08 with the taller tires) getting 18 all highway.
#43
It gets 18 mpg on the highway with the cruise set at 70-75 mph.. Low rpm at cruising speed and lean cruise. The 8.1 does not even have to break a sweat to move the Tahoe. The 99 Tahoe is more than 1,000 lbs lighter than anything that came with an 8.1 from the factory. Also as I mentioned before TUNE is a large part of it.
#45
#49
There was one that was pretty clean with the 5.7 and 5spd, white, AZ car for $4500 almost 10 years ago, and I didn't get it because I didn't want a third vehicle. I know those are hard to come by, and that's probably the one vehicle I shouldn't have passed on. I would pay two to three times that right now for that same thing.
#50
