1998 7.4 vortec performance upgrades
I am saving my money to overhaul my truck I would like to make it the ultimate tow/work truck. Right now it is under powered and slow I would like to put
-heads no bore or stroke needed -cam whats a good one to run for torque -square port intake system -30 lb/hr red top injectors -four barrel throttle body -volant intake -eaton posi -hooker headers ceramic coated, 3inch to the cats, 3 1/2 cat back true dual dynomax round ultraflo welded and high flow cats and maybe a supercharger later on down the road I will also put a leveling kit add a leafs 285/70r17 Bfgoodrich mts and Mamba rims My truck is a 1998 K2500 L29 454 factory auto I will need to do a little bit of rust work and some other odds and ends. This is a work truck and will be used for work just needs more power. |
Mayb check on how much all that's gonna run you. Might be easier and cheaper with better mpg and reliability to find low mile 6.0 and swap
trust me a 6.o cant touch that at same compression because of the displacement
those things always need injectors and fpr get away from bosch injectors , I ran the edelbrock slash gm perf heads on mine 1.8 rockers on a stock cam is a decent upgrade and the proo flo intake will help a bunch the stock intake sucks for performance headers and true duals used to have that engine in my 04 silverado before i went to the 496/8.1 |
I do not want to even mess with a ls based engine when it comes to codes. I do most of the work myself with hel from my brother and friends and we do not have the equipment for them. But I have changed my mind again. I would like to twin turbo it now from seeing what other people are getting for hp and torque.
From what I have found it will cost around 7 grand for heads, fuel system cams, crankshaft, pistons, rods, tranny and turbos with piping. With everything else I would like to do to the truck it would be a total investment of around 12-15k and not having a payment on top of that. It would be epic to pull up next to a pos ricer or some pile like that and tow them at a red light. Also kick my bosses challengers ass. |
Ok so here is my updated thought
-turbonectics ball bearing twins with intercooler and water meth twin gt-k 650 or a single gt-k 1000 oil and water cooled -3" down pipe to 3.5" down pipe back true duals -80 lb/hr trick flow injectors -502 ported ram jet intake -brodix heads race rite ovals 119cc combustion chamber and 270 intake runner ported polished machined -ported and polished intake manifold -arp head studs comp cams 226in/218ex duration 525 intake and 514 exhaust -411 pcm with efi live -still not sure on pistons most likely will convert the tranny mounts to a 4l85e for better build options to handle the power most likely wiseco or manely -manely rods and a upgraded crank -It will be bored .010 over and be able to run on 89 and have propane injection. the goal is 600-700 horse and 900-1100 torque |
What kind of gains did you see with the Pro Flo Intake over the stocker? I've had my eye on that intake.
Originally Posted by xx_ED_xx
(Post 5041156)
Originally Posted by fastnnuffrt
(Post 5040767)
