tuning/wire harness question
Old 04-10-2013, 12:44 PM
TXsilverado's Avatar
Default tuning/wire harness question
a little back story before my question.
i have a 1996 s10 that i did a ls swap on. i am running a carb with a msd ignition box. the box plugs into my coil packs, map sensor, cam and crank sensor.
the truck came with an automatic 4l60e and has the computer and wiring to go along with it. (all in the main harness)
do you guys think it will be possible to use the factory harness/computer to control the transmission while the msd box controls the engine? i really want to clean up the OEM harness but i'm afraid of removing something that will make something else quit working. i HATE wiring.
or should i just scrap that idea and use my TCI/FAST transmission controller to work the transmission?
Old 04-10-2013, 01:06 PM
nonnieselman's Avatar
Why not use the TCI deal?
The factory PCM might be a bit over kill for just transmission duty.
Old 04-11-2013, 12:19 AM
i duno...because it's there and free lol. wouldn't mind selling the tci stuff and buying other parts to finish the build.
Old 04-11-2013, 12:38 AM
Mod with training wheels
smokeshow's Avatar
The factory PCM is going to want all sorts of information to determine transmission shift pressures, shift times, etc. Running that MSD box is going to isolate some/all of the inputs the PCM needs for the transmission, so it likely would not work as simple as you'd want it to. I would just use the TCI box.
ARC
57
02-21-2022 10:54 AM
wcrum17841
08-24-2015 08:30 AM
Jblake
08-17-2015 12:59 PM
USMCvet0311
08-01-2015 07:45 AM
grantpo
07-15-2015 12:21 PM
Quick Reply: tuning/wire harness question
