Overboosting
Old 12-01-2006, 05:57 AM
AeroKing's Avatar
Default Overboosting
My truck keeps overboosting, and i cant figure out why.
I'm gonna apply some psi to the wastegate tonight to see if its hanging up. but i dont think so, cause it moves pretty freely.
Its overboosting at WOT, around 14psi, any less throttle, and it runs fine.
The reason might be becuase i dont have a cat on it...
Old 12-01-2006, 07:11 AM
tech1460's Avatar
make sure you are getting a good signal to the wastegate.
Old 12-01-2006, 08:46 AM
203Cree's Avatar
Nah. With the cat removed, you should see a little LESS boost, since there's less restriction in the system without it. Are tuned for 14psi?
Old 12-01-2006, 09:59 AM
AeroKing's Avatar
my wastegate is set for around 12psi. but my chip can read up to 17. more if i add meth injection.
i have no cat for performance... but i believe for turbos, a cat is used to protect from overboosting, so i think thats my problem.
Old 12-06-2006, 10:12 PM
Import Moderator
beastmode's Avatar
hey brandon by the way... nice ford/lincoln syclone
Old 12-07-2006, 04:39 AM
AeroKing's Avatar
??? WTF ??? are you refering to the Mercury Cyclone???
Old 12-07-2006, 05:46 AM
203Cree's Avatar
No, he's reffering to which section you posted this thread in.
Old 12-08-2006, 11:31 AM
AeroKing's Avatar
i saw Tuning, and assumed i was in the GM section, my bad. But thanks for the info.
Old 12-08-2006, 02:59 PM
203Cree's Avatar
I can move it if you'd like.
Old 12-13-2006, 08:51 PM
Import Moderator
beastmode's Avatar
this is like so off the subject but brandon seems to have abandoned this thread so... cree you got any pics of your truck? ive only seen one plus the one in your sig but the other one i saw was at night, im curious to see some day time ones. thanks man
Quick Reply: Overboosting
