1996 Ford Bronco with rear window issues...
Old 08-12-2014, 05:29 PM
LOBO2's Avatar
Default 1996 Ford Bronco with rear window issues...
I have a 1996 Ford Bronco that is great, except for the rear window having issues.
The window will go down all the way but just barely, though sometimes you do have to push it down. When you bring the window up, it will barely get to halfway then you have to pull it up manually then it will catch and go all the way up.
I've tried new motors, and making sure everything was greased properly but still no joy. The new motors play out pretty quickly, and haven't really done anything except take $$$.
Any ideas?
Old 05-03-2017, 12:23 AM
gonzo 6.2's Avatar
ok ,open tailgate,remove panel, flip tailgatelatch on drivers side this will allow you to use the key and roll out window,may want to use a trash can to support glass.you will find rollers inside the tailgate at the top, lube all that stuff.
Old 05-03-2017, 12:27 AM
LOBO2's Avatar
Thanks for the help, but the Bronco has been gone for about 18 months.
Corvette454l88
09-01-2016 01:24 AM
ss454327
10-17-2015 03:43 PM
thunder550
10-08-2015 04:53 PM
DarkhorSe_SS
08-20-2015 08:58 AM
Quick Reply: 1996 Ford Bronco with rear window issues...
