Quick question...need some input please...5.3 to 6.0 injectors
Old 12-08-2010, 11:02 AM
YenkoST's Avatar
Default Quick question...need some input please...5.3 to 6.0 injectors
I'm helping a buddy change his 2000 Silverado 5.3 engine to a 6.0L using a SS engine as the base. He is also going to use the 6.0L injectors. Do I need to change all the injector offsets to match the Silverado SS injector offsets and flow rates, just the flow rates, or what?
Thanks for the quick answers!!
Old 12-08-2010, 11:24 AM
Resident Retard
BlackGMC's Avatar
i am pretty sure 5.3 stock injectors = 6.0 stock injectors... so nothing should change.....
Old 12-08-2010, 11:33 AM
black04's Avatar
Yeah they are the same injectors.
Old 12-08-2010, 02:42 PM
YenkoST's Avatar
OK...tune shows 24.8 psi....on the 5.3L injectors so thats the correct 6.0L injector too.
I was thinking the 6.0L injector was 28.x. Maybe I got all these durn injectors confused.
Thanks!
Old 12-08-2010, 07:10 PM
FormerVendor
KLUG'S SS's Avatar
The LS1's came with 28.x lb injectors, in the camaros, firebirds, etc.......
Old 12-08-2010, 08:01 PM
YenkoST's Avatar
Gotcha....too much information overload I guess.
Thanks!
Old 12-12-2010, 07:48 AM
sreve's Avatar
I just did a compare between the two engines all injector data was differnt.
Old 12-12-2010, 08:24 AM
FormerVendor
KLUG'S SS's Avatar
Even with the injectors being the same you will find that their are some differences in the injector data from operating system to operating system. My advice to whoever runs into a situation like this is to just go with the injector data from the base tune file they are using.
Old 12-17-2010, 10:46 AM
Custm2500's Rude Friend
1FastBrick's Avatar
There are other differences too. Like the cylinder volume table. It would be best to have a segment swap done.
Old 12-17-2010, 02:54 PM
baSICK5.0's Avatar
They are the same. I personally swapped in my 6.0L and with the current tune the injectors are maxxed out like it sits. If this engine breaths anymore air it cannot add anymore fuel than it is now at WOT. so an upgrade prolly wouldnt hurt, depending on the mods.
OHsixLS3
12-27-2016 09:30 AM
greedygenius
09-03-2015 06:51 AM
GrooveCityZ71
08-31-2015 12:05 PM
Three6GMC
08-28-2015 07:56 AM
JordanH
08-08-2015 07:59 PM
Quick Reply: Quick question...need some input please...5.3 to 6.0 injectors
