Tuning Links
Tuning Links
Here's the first sticky. Let's not discuss the links in here. Only post a description of the link your including in your post. That will make i MUCH easier to find the information your including.
this is a link to the sticky on ls1tech has everything from simple 101 tuning to advanced discussions also has links to a site to share tuning files
https://ls1tech.com/forums/showthread.php?t=287094
Learning to Tune:
--Tuner Software-Tuning 101
--HP Tuners .bin Repository
--Predator Tuning 101
Fuel Trim Cells:
--Fuel Trim Cell Discussion
Injector Tuning:
--*NEW*Tuning SVO Injectors*NEW
--Injector Scaling Calculations
--Injector Duty Cycle Calculations
MAF and VE Tuning:
--MAF Table Tuning (Dialing in the MAF Table)
--VE Table Cracked!
--VE Table Tuning -- Now Hesitation when driving
--Tuning VE via fuel trims
Torque Converter/Shifting Tuning
--Torque Converter locks/unlocks after larger converter install -- FIX
Idle Tuning
--Stop drilling those Throttle Bodies!
--Idle Operation Part 1
--MAF and Running Airflow Tables
Diagnostics/Troubleshooting/Other
--Service Engine Soon (SES) Lookup and Diagnostics
--Detailed Diagnostic Information
--*NEW*GM Driving Cycle (Completing OBDII tests)*NEW*
Learning to Tune:
Fuel Trim Cells:
Injector Tuning:
MAF and VE Tuning:
--VE Table Cracked!
Idle Tuning
Trouble code list.
Did a search for this and came back with nothing so I'm posting the link for everyone.
http://www.obd-codes.com/trouble_codes/index.php
12 Second Club
lots of good info here for LS1 Edit beginners
http://www.noid.org/~lj/PCM%20Tutorial/PCMtutorial.htm
http://ls1edit.slowcar.net/tuning.html
http://para.noid.org/~lj/PCM%20Tutor...reviations.htm
LS1TECH Sponsor
Tuning Links
Help File
HPTuners Forum
Installing-NEW!
Running HPTuners installer-NEW!
Installing MPVI Drivers-NEW!
Pinging your hardware also referred to as resyncing your licenses-NEW!
General
Saving a VCM Suite Info Log-NEW!
VCM Editor
Reading your VCM
Writing Calibration to the VCM
Failed VCM Calibration Write - VCM Recovery
Changing Fan Settings - 160 Degree Thermostat
Applying a 1 Bar SD Enhancement
Applying a 2 Bar SD Enhancement
Using the Compare Feature
Gear Change for 98 LS1 Fbodies-NEW!
Using AutoVE/AutoTune/Copy Paste Special feature-NEW!
Changing Decimal Precision-NEW!
Licensing a file/pcm-NEW!
Applying a RTT(Real Time Tuning) Custom Operating system-NEW!
Applying a RTT(Real Time Tuning) Custom Operating system and Using it via the VCM Suite Scanner-NEW!
Quickly Change Units of measure-NEW!
Using the Comparison Copy over All feature to quickly copy over a starter tune-NEW!
VCM Scanner
Adding and Removing PIDs
Creating a Custom PID and Adding a Custom PID to the Histogram
Creating a user defined EIO Input
Standalone Data Logging-NEW!
Creating and Saving Custom Histograms-NEW!
Using Plot Filtering in Histograms
Using Bi-Directional Controls-NEW!
Reading and Saving DTC's-NEW!
Performing a CASE learn-NEW!
Forum Demos-NEW!
Adding Attachments to a post or thread
MISC
Taking a screenshot
Creating a User Defined Output
Stock OS 1 bar SD Tuning How-To using a wideband oxygen sensor
HPTuners Editor quick start guide
HPTuners SCANNER Quickstart Guide
HPTuners Forum
Installing-NEW!
General
VCM Editor
Reading your VCM
VCM Scanner
Forum Demos-NEW!
MISC
Taking a screenshot
