truck wont take a tune?
Old 07-30-2016, 02:07 AM
blue-03-ss's Avatar
Default truck wont take a tune?
I have a 03 silvarado 2500hd WT with the 6.0 in it. I have burned this pcm a few times and now the only way I can program it is to remove the pcm and use my off board set up. I can scan it just fine but I cant tune the PCM while its in the truck using the truck harness. Everything else works fine on the truck other then the tuning.
Old 07-30-2016, 06:16 AM
madmann26's Avatar
Do you have an aftermarket radio? Does it have any add-on modules like door chime, steering wheel controls,etc?
If you do or it does,try disconnecting the radio.
Old 07-30-2016, 10:20 AM
blue-03-ss's Avatar
yes I do have an aftermarket radio with the chime module. I read something about that and they said to pull the radio fuse. So I pulled the fuse and it still wont take a tune? I'm thinking about ust cutting the class 2 wire from the radio harness?
Old 07-30-2016, 11:08 AM
madmann26's Avatar
Unplug your harness from the factory harness and try and flash it.
Old 07-30-2016, 01:41 PM
About20ninj45's Avatar
We are in the same boat. Been chasing this issue for a while
Old 07-31-2016, 08:48 PM
blue-03-ss's Avatar
it was the radio interface for the aftermarket radio. I had to bypass it so the radio is on full time and has to be shut off with the button on the radio. I will run a wire over to the fuse box and tap into a switched fuse at a later date to run the radio.
Go5.3tt06
05-13-2016 11:49 AM
sharpshooter
04-05-2016 08:13 PM
tim wellington
03-01-2016 10:11 PM
99RedHawk
01-28-2002 10:30 AM
Quick Reply: truck wont take a tune?
