Truck keeps going lean, need help!
Yes but first i need to tune ve for the new cam by using this tutorial on wideband tuning.Speed Density Tuning using Wideband O2 Input by William Henn, 'foff667'
I cant see your tune because I'm on my work computer, but Make sure your Map is wired correctly and scaled correctly. I did this same thing and the 3 bar wiring is different than the stock map. I think it's the center wire is switched. Thing would die and barely run in drive but idled ok
It does have the zr1 map sensor along with conversion harness. I also scaled it for this map sensor. I did put the stock one back on but the problem was still present so i put the zr1 back on.
It's dangerous the way you have it as there is no compensation for a lean condition. READ - if you get bad fuel, your PCM can't adjust fueling to compensate for it.
Mod with training wheels
Injector data is wrong. Idling at 14.7 and going full lean in gear is a indication that your transient fuel needs to lowered. If your logging your injector pulse width at idle what's it at?
