Truck dies randomly while driving - PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 08-25-2008, 11:47 AM   #1
High on diesel fumes
thunder550's Avatar
Default Truck dies randomly while driving
Started having this problem after a 400 mile trip from Phoenix to Albuquerque. My truck will randomly die on me now. From what I can see it seems to happen on when at zero throttle, and it's only intermittent. All that I can see so far is that everything leans way out. I finally caught it in a log file. In this case it happens right before it went into DFCO. You can see how the AFR goes to full lean just before DFCO is enabled, which is not normal. I have looked at other log files and generally spark cuts first, then I see IDC go to zero, then I see AFR lean out. In this case, AFR leans out first, even though IDC is still at 2%.
Does this seem like a fuel pump issue? After I pull over I shut the ignition off, then turn it back to run and check fuel pressure, and it's fine. I have not yet looked at fuel pressure right when the truck dies, but I would think that if the pump quit working that it wouldn't start again. It usually takes me 2-3 tries cranking, turning off the ignition, turning to run, then cranking again to get it to start. Once it starts, everything seems normal. This issue seems to happen once or twice a day.
I have also attached the log file, this issue starts at frame 988. Tune file is also attached.
thunder550 is offline   Reply With Quote
Old 08-25-2008, 03:02 PM   #2
64CAMINO's Avatar
Yay, your truck learned a new trick. it plays dead!
64CAMINO is offline   Reply With Quote
Old 08-25-2008, 04:53 PM   #3
thunder550's Avatar
It's also been getting increasingly difficult to start after sitting for awhile. Took me about 5 tries leaving work this morning, and about the same number leaving work to go to lunch. Fuel pressure is good when this happens. Just sits and cranks with no fire.
Old 08-25-2008, 05:03 PM   #4
something else
ChevyTruck's Avatar
Quote:
ROFL. now that is not nice.
damn man that does suck...
ChevyTruck is offline   Reply With Quote
Old 08-25-2008, 05:10 PM   #5
thunder550's Avatar
Well it intermittently idles like **** now too, feels like it has a miss. Looks to be rich, but not rich enough to make it feel like it has a miss. Only in the 12.5:1 or so range. I'll mess around with the idle tuning a little bit. I decided to try and disable DFCO also and see if it changes anything. This is extremely frustrating.
Old 08-25-2008, 05:22 PM   #6
64CAMINO's Avatar
I would start with your ignition stuff, coils packs etc..
Old 08-25-2008, 05:35 PM   #7
64CAMINO's Avatar
I guess it would not be an individual coil pack, that would not kill the truck. it has to a wire running to the coils, possible ground issue? maybee a body ground has come loose. your alarm has been acting up to. just thinking out loud.
Old 08-25-2008, 05:58 PM   #8
thunder550's Avatar
The issue with the alarm is in the interior fuse panel on the driver's side of the dash. I've had the same problems with it in the past...just a loose connection somewhere. I'm 100% sure that it's not related to the other problems I'm having. I'll have to check the other grounds.
Old 08-25-2008, 06:18 PM   #9
How do I change this text
Wilde Racing's Avatar
do a balance test if you can.
Wilde Racing is offline   Reply With Quote
Old 08-25-2008, 06:23 PM   #10
64CAMINO's Avatar
Injector driver box not responding at low voltage such as idle/starting.
Thread Thread Starter Forum Replies Last Post
selling some tools, take a looksy Tig Miscellaneous Classifieds 12 09-30-2015 08:39 PM
2011 Silverado 6.2 supercharger build...FINALLY!! wrb002 PROJECTS GALLERY 18 08-31-2015 01:00 PM
Feeler 2004 Turbo Silverado SS black6spdz Trucks and SUV Classifieds 9 07-16-2015 02:32 AM
All cleaned up 03sierraslt SHOW & SHINE DISCUSSION 6 07-11-2015 03:47 PM
HELP NEEDED OBS LQ9 swap going into reduced engine power mode GreyChevy Tuning, Diagnostics, Electronics, and Wiring 1 07-07-2015 09:57 PM
Tags
00, 1500, 1976, 2006, 60, 76, chevy, dies, driving, dying, middle, randomly, silverado, stalls, starts, truck
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
