Tru Cool 40,000
Mine goes straight from trans to trucool and back with -6 hose and I see 135-140 F temps when cruising around in upper 90s to 100 degree temps. Back to back runs at the track produced temps in the upper 170s. I've also seen as high as 190s temps on a 4k stalled heavy denali truck on back to back dig runs. So, yes the Trucool can see temps over 150 (I've come across countless posts of people claiming they never see over 140-150 temps), you just need a setup that can produce that amount of heat. But in your instance, I'd imagine the issue is running through the radiator and maybe minimally it's position behind the FMIC.
with temps 110 degrees+ outside, mine runs about 160-165. I run mine thru the radiator. before tru-cool it was 190+, I don't even see that now pulling a 5000lb trailer.
Just add another temp range. My 40k by pass the radiator. Just regular driving I see 150 to 160. Driving hard for few pulls will creep up to 180. This in 90 degree weather.
MASS seller approved
Here in Michigan, on my Silverado SS with a 414ci engine and a 3600 stall converter, I would constantly see 190-210 while driving around with the stock cooler. Tru Cool 40k took me to 160-180 while driving around. I ran mine thru the radiator for the winter months, but it still ran on the cold side during winter.
Anyone looking for an install kit, I highly recommend checking out: https://www.performancetrucks.net/fo...rdware-508374/
im seeing 130ish here in Virginia on my silverado and i beat the hell out of mine. mine only uses the cooler. no radiator. i have one on my 02' Excursion and towing 11k pounds across country and towing uphill climbing Tehachapi pass and the blue ridge mountain i seen 180 tops. im also running 37's.
