Stall won't lock up.
Okay so the truck just got a freshly built transmission and when I drove it out of the shop all gears would kick in and the stall would lock up. Now I got some trouble codes for a malfunctioning solenoid and the fluid pressure. The stall wouldn't lock up. Now I took it to the transmission shop and he said it needs to be retuned so the stall can lock up, but I don't feel like throwing down 50$. I have a 6 month warranty with the transmission shop so should I just get him to replace it, because I don't think a retune would help.
If it didn't set those codes and locked up before being rebuilt it shouldn't set those codes and should lock up after being rebuilt.
You sure it locked up before? False misfires caused by a cam can prevent lockup. Regardless it shouldn't be setting any trans codes. Was the converter and cooler flushed with the rebuild? If not it could have put a bunch of trash back in the trans after driving it.
It was fluid pressure codes. And malfunctioning solenoids.
Okay so I got the truck back and the stall still won't lock up. I all went full throttle and it bounced off the rev limiter on the last gear. I was so happy to get it back and it's acting up again. Well now I'm going to take it back to them Monday.
Took it to my tuner, he used his computer to manuelly shift the truck and the truck still wouldn't lock up. Then on wot it began to slip. I hope these guys didn't do me dirty. He gave me a 6 month warranty so I'm taking it back on Monday.
