Schematics, Pinoouts, Training Materials, Technical Documents
Old 01-12-2012, 10:11 AM
11 Second Club
Phantom's Avatar
Both? I'm not 100% what I'm looking for so everything I can get is helpful
Phantom is offline
Old 01-12-2012, 11:25 AM
FormerVendor
CalEditor@PCMCalibrators's Avatar
2007 GMT-900
Let me know if you need the next step in a Schematic
CalEditor@PCMCalibrators is offline
Old 01-17-2012, 11:02 AM
11 Second Club
Phantom's Avatar
was just curious if you ever came across the stuff for my 2007. Thanks
Phantom is offline
Old 01-17-2012, 11:11 AM
FormerVendor
I will fix that post
Old 02-03-2012, 10:38 AM
KHester84's Avatar
Can you help me figure out where this pin gets power from? I want to hook my wideband up to it and need to make sure it can supply 10A. This is the distribution box under the drivers side dash. Thanks.
KHester84 is offline
Old 02-03-2012, 11:38 AM
FormerVendor
2008 GMT-900
Junction Block - Left I/P X14 (5Y0/5X7/9L4/AYE/SPO Heated Seats/SPO DVD)
Pin #7 Would be used for -- Ignition Voltage (SPO DVD)
Looks like the underhod fuse block Fuse #54
Old 02-04-2012, 03:29 PM
RacinRust's Avatar
Good info ! I was about to use X-14 as a low amp switch source for front and rear external lighting. In X-14 it shows cavity 2 and 5 as battery feed. These are Bat + correct ? Not switched?
I bought the connector 20791502 to use for this but am now having problems getting the terminals that go in it. Also can I use pin #1 for a ground source for the low amp switch?
I have access to the 2011 Electrical Manuel for my 2011 1500 silverado.
Thanks for your help.
RacinRust is offline
Old 02-04-2012, 03:48 PM
FormerVendor
2008 GMT-900Name:  SPODVDConnector.jpg
Connector Part Information
• Harness Type:
• OEM Connector: 13516837
• Service Connector: 13585326
• Description: 8-Way F GT 280 Series (BK)
Terminal Part Information
• Terminal/Tray: 13525970/4
• Core/Insulation Crimp: E/A
• Release Tool/Test Probe: 15315247/J-35616-4A (PU)
Pin -- Wire -- Circuit --- Function
1 ---- BK ---- 1050 ---- Ground (AYE)
2 ---- RD ---- 4540 ---- Battery Positive Voltage (AYE)
3–6 - — ----- — ------ Not Used
7 ---- RD ----- -- ----- Ignition Voltage (SPO Accessory – Headrest DVD)
8 ---- 43 ---- 5289 ---- Accessory Voltage
Old 02-04-2012, 10:29 PM
RacinRust's Avatar
Thanks
Old 02-04-2012, 10:55 PM
Stoichiometric's Avatar
I'm looking for information for the IGNITION 3 VOLTAGE wire for a 2002 2500HD. Same wire as in this thread. The last post has me confused and I want to double check.
Connector C100 Pin N, "Ignition 3 Voltage"?? - LS1TECH
Stoichiometric is offline
Quick Reply: Schematics, Pinoouts, Training Materials, Technical Documents
